ExtLibA.SockLib.InitHAFLibFail
Description
Failed to initialize HAF library.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Error
Message Text
Failed to initialize the HAF library. Error code = %p1% Socket index = %p2%
Message Parameters
Name Type
p1 xInt8
p2 uInt32
